BH Series
3.6-6 kW | Single phase | AC-coupled retrofit inverter (HV)
POWIĄZANE PDF >>
Przewiń
HV Battery
undefined
undefined
The GoodWe BH Series inverter is a single-phase, AC-coupled retrofit inverter compatible with a wide range of high voltage batteries from 85V to 450V. It is designed to maximize self-consumption with UPS-level switching backup function. The pre-wired communication cables and AC connector’s ‘Plug & Play’ simplify installation, operation and maintenance.
Maximize self-consumption
Pre-wired communication cables
Plug & Play AC connectors
Hybrid systems converted
<10 ms UPS-level switching
HV Battery
undefined
undefined
85~450V Wide Battery Voltage Range
Compatible with various high voltage batteries (GoodWe, BYD, Pylon, etc.) Flexibility and affordability to fulfill different customers’ energy storage requirements.
Easy to Install and Maintain
Pre-wired communication cables greatly shorten installation time. Plug & Play AC connector simplifies O&M.
Compact design
GW3K-BH
85~400
Max. Charging Current(A)
32
Max. Discharging Current (A)
32
230
Protection Degree
IP65
GW3600-BH
85~400
25
25
230
Protection Degree
IP65
GW5000-BH
85~400
25
25
230
Protection Degree
IP65
GW6000-BH
85~400
25
25
230
Protection Degree
IP65
Jestem...
Instalatorem
Dystrybutorem
Użytkownikiem
Inni
Podaj kod weryfikacyjny:*
