Język
5 kW+10.8 kWh | Single phase| Home storage solution (LV)
POWIĄZANE PDF >>
All-in-one
Easy installation
GoodWe ESA Series is an all-in-one solar and storage solution which integrates the inverter, battery charger, UPS-level switching and battery enclosure into a pre-wired modular system for easier and faster installation. The compact, elegantly designed and robust unit is IP65 rated so it can be mounted either inside or outside withstanding all weather conditions. Reduction of installation time of up to 50%.
Integrated isolators
Module-design pre-wired
<10 ms UPS-level switching
10.8 kWh battery capacity with 100A maximum discharging current
All-in-one
Easy installation
This masterpiece perfectly integrates with a 5 kW hybrid inverter with a 10.8 kWh Lithium battery inside. Additionally, the exquisite ESA series occupies less space and offers neater installation than a split storage system in order to create a high-performance system that is aesthetically pleasing.
The smart hybrid system has been designed to make installation easier. The modular system is expandable with battery storage to suit the customer’s needs. The lightweight, maneuverable system makes installation a breeze.
10.8 kWh battery integrated
GW5048-ESA
40~60
Max. Charging Current(A)
90
Max. Discharging Current (A)
100
Number of MPPTs
2
Number of Strings per MPPT
1
