Język
3.6-5 kW | Single phase | AC-coupled retrofit inverter (LV)
POWIĄZANE PDF >>
Export control
Grid-interactive
The GoodWe SBP series is the world’s first AC-coupled battery storage retrofit solution with UPS function for both single-phase and three-phase systems. It can effectively upgrade any existing string inverter system by adding a backup battery. Capable of being grid-interactive, it allows users to store surplus power and sell it back to the grid when demand peaks and the price of electricity is at its highest. With UPS-level switching function (switching time <10 ms), the GoodWe SBP provides uninterruptible power supply to inductive loads such as air conditioners or refrigerators.
Suitable for both single-phase & three-phase systems
Export control (zero export)
Smart BMS
<10 ms UPS-level switching
Export control
Grid-interactive
GoodWe SBP provides uninterruptible power supply (UPS) to inductive loads such as air conditioners or refrigerators.
GoodWe SBP is designed to interact with the grid. In this case, SBP allows selling electricity back to the grid or charging batteries through the grid.
GW5000S-BP
48
Max. Charging Current(A)
100
Max. Discharging Current (A)
100
230
Protection Degree
IP65
GW3600S-BP
48
75
75
230
Protection Degree
IP65
